Just move the battery to the trunk and rock that shit the way it sits
I can't turn my new upper manifold around!
Originally posted by Grandmarchris View PostJust move the battery to the trunk and rock that shit the way it sitsNick
88 Colony Park LS
Originally posted by mrltd View Postwell, if it's gonna be some stupid quick track car, start hacking and use the stang stuff. Get mustang accessories also, it'll make everything much easier and you'll have less problems in the longrun with havign to buy a $150 ASP underdrive for a vic.
If you dont have a/c you can use the march pulleys I used to underdrive the water pump and alt. I think it was like 60 bux for the water pump and crank pulley
The offset was correct for that? I'd have figured the fox pullies would have the belt running somewhere between where the stock ac and alternator belt sits.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostThe offset was correct for that? I'd have figured the fox pullies would have the belt running somewhere between where the stock ac and alternator belt sits.
Originally posted by 87CrownVic View PostHey, is anyone running the professional products fuel rail and regulator kit on top of their SEFI 5.0?
As for regulators, I'm going back to a stock one. Car never ran right when it was set other than stock, and then it failed. I went and bought a Motorcraft part to replace it.86 Lincoln Town Car (Galactica).
