might as well do it all at once. the oil is going to need to be changed after the timing set and after the intake if you do them at seperate times. Can't run a motor with coolant in the oil, it will take out the bearings real quick. I made that mistake on my own car, 60 miles later I had no oil pressure and a rod knock.
loss of coolant... then i found it...
I just figured that I'd inform everyone... the Deuce is fixed. New timing set, water pump, thermostat, and intake manifold gaskets. Runs like a top!
And no more coolant leakage, lol.1984 Ford Crown Vic LTD, The Murphmobile (RIP)
