My rear end
    You sure it isn't just a 1982 country squire CHASSIS?
      rears
      "I like big rear ends"
      But we are talking cars here.............................................. ........................LOL
      On gear ratios, I ran the racecar for a couple of years with 3.73s and a 28.5" tire, driving to and from the track, some hiway cruising and around town daily driver status. 70mph was 2400+rpm IIRC.
      I thought 3.73 was too much gear for the street, and not enuff for the track. My choice for a dd would be 3.55s.
      I am still using the original driveshaft even with 4.56s and a C-4. As long as it is in balance, there should not be a problem.
      That rear should be an 8.5 on an 82. The 8.8 came out in 83.
      Either way, if it is an 8.8, any 8.8 r&p should bolt right in.
      If it is an 8.5, you will need a new carrier for the 8.8. Use a factory 8.8 posi unit for the new carrier. Rebuild the rear with new bearings etc. while it is apart.
      As far as an intake, the factory Stang intake from 83 thru 85 and its corresponding 4180 HOLLEY makes a good street combo due to its small internal runners, and 4 corner idle adjustments.
      Ran that combo on the street for several years as a replacement for the VV.
      Speed cost....how fast u wanna go??
      It's not how much hp u have...
      It's how much hp u can put to the track...
      Let's seperate the men from the boys and put that power to the track using street tires and stock suspension components
      'Tis infinately better to sit quietly and be thought a fool,
      than to speak and remove all doubt.
      I refuse to have a battle of wits with an unarmed person.
        Im running a 4.10 in mine with and aluminum shaft, but im also running a 32" rear tire. rpms unknown at this time due to me blowing the tranny.
        1989 Grand Marquis LS
          Yeah it is the 82 chassis but also the 82 8.8 / engine and tranny came with it.
          Vehicle: 1965 Pontiac Catalina (fastback 2+2)
            Just a chassis?
              Well, it has a 1965 Pontiac Catalina body on it, but I never mention that because it complicates things.
                I have pic some where in this forum.
                  http://www.grandmarq.net/vb/showthread.php?t=18372
                    Originally posted by 82LTDQS View Post
                    Would a governer change help with the whole shifting late thing ???
                    unless i missed something... what shifting late thing?
                    i've never heard of anyone putting the stang governor on a stock box but from what i've read its pointless because it doesnt make the power for it. the governor only changes wot shifts.
                      Originally posted by Mercracer View Post
                      I wouldn't make a blanket statement like that.......
                      i have a stock driveshaft and 3.73's in the towny.....no problems..the vic wagon is gettin 3.73's soon........now i wouldnt suggest 4.10's for the street....the volvo wagon has 4.10's i hate em.....i'ts in overdrive at 35 mph and the tv pressure is maxed.......my 89 vic has 3.55's and the towny has 3.73's.....the towny highway mpg is slightly lower at 22 mpg
                        Oooooh, that one. That thing's kewl; I think I need to do something similar one day. Man I'm slow sometimes!
                          Torquelover mentioned that his shift points were screwed up since he installed his 3.27 gears, so I asked if a governer change would help.
                            ok..my bad....I guess it would be more fair to say that if you do a lot of hwy driving and you plan to go 3.73 or higher, a different D/S like aluminum might be a good idea.
                              As the others have said, not an 8.8 unless someone swapped one in. Decode your tag using the attached picture.
                              Tag should say the following (Conventional followed by Traction Lok):
                              2.73 - WGY-C or WFZ-D
                              3.08 - WGY-A or WFZ-B
                              3.42 - WFZ-F or WFZ-G
                                My '82 with 3.08's starts vibrating about 80 MPH. '88 Wagon with 3.27's doesn't vibrate up to about 95MPH. After that I don't know. Both have steel driveshafts.
                                Box Police cars (and some later box civilian models) had aluminum driveshafts.
