Crane 351 Distributor...
    Anyone have any experience with this?
    http://www.cranecams.com/index.php?s...&lvl=4&prt=127
    9 timing curves at the twist of a dial. Has a built-in MAP sensor?? Any difference in performance between small cap and large cap, or is it mainly due to space issues?
    i'm guessing the map sensor would be to change timing curves for boost or something.
    large cap lets you run a bit hotter ignition without fear of the spark crossing over to another tower. most companies went to a bigger cap with the electronic ignition because it was a fair bit hotter than the breaker points.
