Cam/Computer reprogram
    As most of you know, I traded Dave my 2 door LTD for his Lincoln Mark VII. Seeing as how the motor has close to 300 000 kilometers on it I'm gonna give the motor a fresh rebuild. I want to put a better cam in it to but a couple people told me that I would have to get the computer reprogrammed to accept the new cam or the car will run like shit. The Mark VII btw is a 1988 and has a 5.0 liter H.O.
    to get the best performance,milage, and drivability yes. but if it's a small cam, it should be fine. I'd look for something really small and eec4 friendly. Just FYI, HO cam has been used in 10 second cars...
      i dont think it needs reprogramming since its EEC IV, however you can chip it if you like and have a port to hook your comp too i think www.fordfuelinjection.com has lots of info
        chip= reprogram
          Its speed-density, you have to be careful with your cam selection. If your cam screws with the vacuum signals too much it will run horrible. It is possible to mass air convert the thing though if you need to. DO not listen to mustang weenies about cam choices for a Lincoln though, you will not be happy with it. They build high rpm no torque motors for lighter cars. The Mark VII weighs right around 2 ton, and is about 500 lbs more than a Mustang. You'd do well with something like one of the mild Comp XE series cams, a 258 or a 264 should do the job, both of which are SD friendly from my understanding.
            dont MARK VIIs weigh the same as a convertable GT stang?
              the 264 is a tad big, unless you do a stall converter and at least 3.73s or 4.10s
              Trust me I know....
              An explorer cam would work nice... The stock HO cam seems a bit much for those cars too. Even with a 2200 stall and 3.73's my buds LSC was kinda dogged until 2500 rpm. Stock motor....
                Prolly a bit more than a vert stang, maybe an vert SN95 or one of these newer pig stangs... They are boats.
                  mk7 weighs about 3900 lbs
                    yeah right around 3900 for a vii. They weigh as much as a Crown Vic.
                      A Crown Vic weighs around 3500 lbs.
