how good are 302 ford truck heads?
    My friend has got a set im looking to get for the tudor and I was just wondering how much of an improvement would it be from an e7? They would be port and polished for around 250 with recut vavles.
    Uh, what year is the truck?
      E6TE heads??
        if they are 87 and newer heads they are e7's....same as the 5.0 ho
          What they said, 87+ is the same thing. Early truck heads aren't any better either.
            'Tis true, my 351 E7s were from an F150.
              I'm sorry for being slightly off topic, but what heads come on 351W trucks? Are they E7's too? Did they change with different model years?
                my 351W came out of a 89 Ford truck. had E7 heads, just drilled for the 1/2" head bolts vs. the 302's 7/16"
                  Drill the block for 1/2 headbolts
                    already have them since it is a 351
                      think they were 89 or 91? idk i think i might just find my self a nice set of gt40s or e7 worked.
                        Why would you want to do that instead of using the collared adapter bushings on the heads?
                          More clamping force since the studs are larger. Requires machine work to do. A 351 doesn't need it, since its already got 1/2" studs.
                          83countrysquire: the truck heads are E7 heads, they will work fine for you.
                            well guys my plan is to make my car just hit a high 14. My plans so far are a performance intake ( I dont know which one yet) cam(http://store.summitracing.com/partde...2&autoview=sku), heads(gt40 or a good set of e7s), tb(65mm), bigger injectors(21lb),3.55 gears, shift kit and thats all i got so far as a plan. I got a friend who goes to pen college of technology and is certified and has been building motors for a while, he says he will help me all the way through the build and help me tune it and make it a beast, he wants me to make a bbk ssi intake for it but I wanted to make sure that it was a good plan for a build. Any suggestions.
                              Sounds like a very helpful sort of friend! I hadn't realized this car was fuel injected.
