hi everybody im new to the site.i know that this is probably a really stupid question but which hose do you put the seafoam in by the brake booster? I dont want to put it in the wrong one. pictures would really help me if you guys could
where to put seafoam
there is a vacuum hose on the front of the intake that goes to the charcoal canister purge valve.....good spot to suck the seafoam in.....nice and slow with it shut the engine off right away and wait about 20 min and then start it up and watch the smoke
oh and welcome to gmn!
i still would rather pull off the upper intake and clean it all out with carb ceaner and a small wire brush. the time it takes to put it all together with the carb cleaner sitting inside the engine it will clean it good. i wire brush he stuff than hit with carb cleaner to soak in than brush it again and rinse with another blast of carb cleaner. here is a link to the crap of how i cleaned it by hand....
http://www.grandmarq.net/vb/showthread.php?t=22300
you will have to go to response 13 to see the lower intake how i cleaned it out. fuel injection cleanings at shops dont do much inside of an engine doesnt do much good for cleaning the stuff out too good. jelybean's car (AF) had an injection cleaning with stuff thru a vacuum line and in the tank. i ended up cleaning it by hand since it was full of carbon also and the EGR port in the spacer was blocked completely.
I added it right down the carb on mine (I understand that the car in question is FI). But, I didn't see much smoke at all, and I followed the directions to a T. I guess there just wasn't that much buildup... which doesn't really surprise me...**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
ya when i did it, it started to smoke a lot while i was pouring it.then it finally stalled and i poured the rest in and waited. it didnt smoke as much when i started it so i thout i had did something wrong lolLast edited by Jonsey; 03-19-2008, 12:20 AM.sigpic-The Crown(Kodiak)1989,150K Miles,5.0LOpo,autolamps,slicktop,power windows and locks,yet still not good enough to be LX:confused:
oh yea i forgot.does it matter if you didnt put it into the oil?because i just put it in the intake and tank.do you still have to get an oil change?because if ya do, il just go get another can and put a little in the oil before i change itsigpic-The Crown(Kodiak)1989,150K Miles,5.0LOpo,autolamps,slicktop,power windows and locks,yet still not good enough to be LX:confused:
yea you should change your oil soon if you did it through the pcv or any vacuum source. if you put it only in your gas tank you wouldnt have to change the oil.
if you put it in the oil be careful of how much and change it out after a really short drive.. i dont trust driving around with seafoam mixed with my oil for hundreds of miles like some people.Last edited by cld783; 03-19-2008, 12:40 AM.Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
