i was wanting to put a shift kit in my 85 2-door grand marq and was wondering what brand i sould go with i was looking at a B&M but i don't know where i can get one
shift kit
shift kit
---1990 Lincon LSC., 5.0 H.O., 55,000 ORIG. miles, 3:73 Posi, Bullit rims, 3G alt., 2.5" full-back exhaust, Mark 8 elec. fan, Flowmaster mufflers. My DD
---1985 Grand Marquis 2-door., Fresh 5.0, slick-top, GT40P's, 1.7 RR's, FRPP headers, 3G alt., Weiand Stealth intake, 650 cfm holley, 2.5" side-exit exhaust, Mark 8 elec. fan, 3:55 Posi, Bucket seats, custom center console. My ToyTags: None
Summit Racing sells B&M and TransGo. Another brand some guys talk about is Bauman (Baumann?). What I've been hearing around here is that B&M kits really don't do much. Cool thing about TransGo is that they have a kit that not only allows things like Third to Overdrive at WOT, but includes their AOD-HIREV 6000 rpm governor as well if you've got an engine that can use it ... torquelover's '87 P72 has a TransGo kit in it and it's a blast to drive.2012 Mazda5 Touring | Finally working on the LTD again!
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
I've got a B&M in my car, and it's decent, but not great. The 1-2 shift is still a bit sloppy, though I'm honestly not sure whether that's the kit or the transmission itself. I've never used a Baumann, but I've heard nothing but good things about them. Here's the link if you're interested:
http://www.becontrols.com/products/aodcat.htm
Come to think of it, I also saw little improvement when I installed a B&M kit in a stock tranny with a stock converter. Doesn't Colin's tranny chirp the tires with no valvebody modifications at all?2012 Mazda5 Touring | Finally working on the LTD again!
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Yeah, that AOD in his car shifts quite firm, even though he swears up and down there's not a shift kit in it. It's rather odd.
I asked about a mild shift kit awhile back. Everyone on here seemed to recommend the TransGo NoYoYo. Eveyone one The Corral said to get a Baumann. Both keep OD lockout unlike many AOD shift kits.
According to The Corral, the reason Baumann is good is that it is fully user programmable, from mild to wild.1990 Country Squire - under restoration
OD lockup is determined by the converter itself, not the shift kit. AODs use a dual input shaft setup, the inner one runs 3rd and 4th gears, and the "socket" it sits in on the converter is actually welded to the converter shell itself.86 Lincoln Town Car (Galactica).
Originally posted by Nathan in MN View PostYeah, that AOD in his car shifts quite firm, even though he swears up and down there's not a shift kit in it. It's rather odd.Scars are tatoos of the fearless
I was going to help a friend put a BEC kit in his T Bird. But, he got rid of it before we got around to it. I am quite certain that kit involves drilling holes in the vb. I know some say all you have to do is drill holes in the seperator plate; but I looked through those directions, and it looked to me as though you had to drill holes in the vb.
I was thinking of getting the kit from him, but I don't have another vb for a post '89 trans, if I mess this one up.**1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Cruiser
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
All I've ever seen on shift kits is drilling holes in the separator plate. You change out a spring or two in the valve body, but you don't add any holes.
Originally posted by Nathan in MN View PostAll I've ever seen on shift kits is drilling holes in the separator plate. You change out a spring or two in the valve body, but you don't add any holes.**1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Cruiser
I have a mild Transgo in mine and am happy with it. The shifts are nice and firm, and it works well despite the AOD's inherent flaws and quirks. I had a Transgo in my first car, a 92 Grand Am GT and was happy with that application as well. However the Mercury, I upgraded the servo and used the Kevlar bands.sigpic
1986 Grand Marquis LS 2 Door
Originally posted by P72Ford View PostYou see, thats what I was told. I'm going to have to ask my friend to get me the directions. It seems bizarre to drill a hole in the vb. I remember him saying it was for a "relief valve" or something.
I've been validated...**1976 Ford F-150 4WD: 360, 4 spd, 3.50s, factory A/C, 4" lift, Bilsteins, US Indy Mags, 35s Cruiser
