this morning i start up my car and it starts and it was idling at like 300 rpm but yesterday it ran fine. It would rev up just fine but it would still idle like shit.
What would cause this?
change in weather......is it ok after its warmed up and driven a bit?
could try cleaning the idle air control valve it might be sticky
yeah its an 85 and yeah i pumped the gas.
Where is the iac valve located?
there is no spoon......sorry thought u had an 86 or a 87
CFI cars use a throttle kicker and a high idle cam operated off a choke coil. If the high idle linkage is sticky, it won't flip down to keep the idle up as the engine warms. Basically if you happen to know anything about carb choke systems, you can figure out a CFI unit. Same sort of choke setup.
