Do I need to change the govenor in the trans if I only plan to keep the car in second gear on the track?
Trans govenor
you cna hold 2nd as long as you want... It's the same as a mustang. pull lever to 1 run it up to what ever rpm, put it in D , let it shift into 2 and pull lever to 1.....Builder/Owner of Badass Panther Wagons
epoxy mod baby:
http://www.clickclickracing.com/foru...ead.php?t=281786 Lincoln Town Car (Galactica).
So that's how you do that! Is OD just fully automatic, then, you just don't have any Overdrive Lockout option?
I'm planning to try my hand at modifying my own AOD governor .... first I'll wait and find out how I did with the material-removal from a C4 governor weight, then later on I'll start looking more seriously at at the AOD.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostSo that's how you do that! Is OD just fully automatic, then, you just don't have any Overdrive Lockout option?
I'm planning to try my hand at modifying my own AOD governor .... first I'll wait and find out how I did with the material-removal from a C4 governor weight, then later on I'll start looking more seriously at at the AOD.86 Lincoln Town Car (Galactica).
for those who don't want the electronics. A stand-alone controller isn't cheap either. Its possible to wire in a stock 4R70W car PCM piggy-back to the engine ECM to control the trans, but you best know what you're doing if you're gonna tap into all that mess. Not really an option for you carb people, no stock ECM to piggy back the sensor inputs.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postfor those who don't want the electronics. A stand-alone controller isn't cheap either. Its possible to wire in a stock 4R70W car PCM piggy-back to the engine ECM to control the trans, but you best know what you're doing if you're gonna tap into all that mess. Not really an option for you carb people, no stock ECM to piggy back the sensor inputs.sigpic
https://www.facebook.com/jason.baker.1614
1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
or if you own a Lincoln, they already use a longer transmission. A 4R70w is actually about 1/2" shorter than the Lincoln AOD, which is not enough to worry about.
Not everyone wants the wiring and the electronics. Personally, I'd love to do this with my car. Programmable shifting FTW. Screw all the fussing and fiddling with an AOD valve body to get it right. Maybe when my AOD dies in another 100k I'll do this.86 Lincoln Town Car (Galactica).
