does anyone know where to get these or if the injector o-rings are the same size, ford says they dont carry them anymore, the spring clip orings
fuel spring line O-rings
probably napa. Not sure if the injector O rings are the same size but I suspect they aren't. I imagine that a decent store has a drawer full ot fuel system compatible O rings that they can match up the original to.86 Lincoln Town Car (Galactica).
ecklin 2-12085 from napa.....need 8 kits mang
scott... he is talking about the o-rings on the fuel line, where it connects to the fuel rail.
should only need 4 total (2 for each side) I think I got some Napa the last time I replaced some. just need to match the old ones for the correct size and thickness. also make sure the replacement o-rings are fuel rated, meaning the fuel won't eat the rubber. Factory o-rings are brown.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
I know for a fact that the ones for the injectors are too big, I've tried it several times. I just got a variety o-ring box from advance auto.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
