Hello team,
I recently (Just before last winter) installed a rebuilt engine into my 89 grand marquis gs with 51k on the clock and I was wondering if anyone has some advice related to a few problems that I have. (The reason for needing to put the rebuilt into it is long and sad)
1. Flat spot in acceleration. I've read the sticky on the TV cable I'm going to check out my cable adjustment. After a shift, if I'm under a state of light throttle, the acceleration can be minimal or nothing. I"ve found this when cruising on the highway and suddenly find myself only doing 55-60 and need to accelerate. I get virtually no acceleration until I move to higher throttle and the trans downshifts.
2. Smog Pump. On the smog pump, I have one set of hoses going to exhaust system. I also have one wrapping around the upper back side of the engine and T'ing off. A third nozzle, exiting the air pump, is unconnected. This is the one that I'm wondering about. If I plug the hole with my finger the engine idle and noise changes.
3. Idle speed: It's a bit high, (not sure how much) and it may be related to the smog pumps not being completely connected. If not, I checked the signal to my IAC valve to be around 11.5 volts. Haynes says ~10.5 is normal. I'm not sure if that difference is the source. I haven't checked the valve itself for cleanliness.
4. Squeal: I hear a squeal at idle as well as whenever I come off the highway and my foot is off the gas. It sounds alot like a belt or pulley. The tensioner pulley has some play in it. (Rocking it top to bottom) The noise goes away almost completely when I put my foot on the brake and get vacuum assist. (When in park or drive) It also goes away when I put the car into reverse or drive. This might be air pump noise or it may be related to number 5.
5. Water Pump Bolt: I'm missing the bolt on the left side of the water pump that also has a stud coming out of it that the tensioner shares. I'm using a long bolt with a washers to replaced a bolt (with prodtruding stud) and nut. The fact that the washer thickness doesn't match the OEM bolt head thickness may be causing the belt squeal at idle.
Thanks in advance by the way for any info. I'd post pictures but I'm too cheap to buy a digital camera.
