I am so fuckin' pissed of at that shop, right now, I can hardly think.
New plugs are in. Used Autolite 25's gapped at .45. Only improvement, so far, is that the car has a little more "pep". Engine still shudders at idle. I removed Motorcraft 44C's from the heads that were gapped at .50.
I replaced the two small hoses that come off the pump (mentioned previously) and found them to be quite old and worn. Why were these not changed in the first place?
Before I took the car in to the shop, I specifically told them to replace the oil pan because the rear plug threads were stripped (someone had cranked a metric plug into a standard thread hole before the car was purchased). What does the shop do? Gives me an oil pan with metric plugs and, what seems to be, stripped rear oil plug threads. I had to play with that rear plug almost as much as the old pan just to get it out and in.
Now, the show stopper. I actually stopped breathing when I saw this. My transmission pan is COLLAPSED! Looks like they didn't know how to support the trans when removing the engine.
I'm enraged. $2600 paid to the shop, not to mention a few hundred dollars in fuel with all the bullshit running back and forth ... and ... all the extra money spent on parts since I've got the car back ... O2 sensors, coolant, hoses, spark plugs, fan clutch, and IAC valve. AND IT STILL DOESN'T FUCKING RUN RIGHT!!!!
The "ptth" out the tail pipe is still there, too. It's been suggested to me by a neighbor that they possibly didn't lube the cam properly before installation, thus stripping a lobe enough to cause trouble.
This was supposed to be the top shop in the whole fucking state. What a bunch of bullshit that is. Going to be paying them a visit first chance I get.
