from efi to carb
    then that is what i am going with. I want as few hoses and wires in my engine compartment as possible.
    my cardomain page is http://www.cardomain.com/ride/2944469
      I have never had problems with HEI ignition.
      Vehicle: 1965 Pontiac Catalina (fastback 2+2)
      Chasis: 1982 Ford LTD Country Squire
      Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
      Big Brake swap and front suspension completed.
        Originally posted by portdizzal View Post
        221- 302. That doesn't include 351, which is what you want, correct?
        I'm thinking maybe the taller deck height of the 351 might affect the length of the distributor? Maybe not, but it doesn't say it fits a 351, assuming that is still what you are going to use.
          well i decided to stick with the 302. i will just bolt on a 50hp nitrous fogger for a little extra power when needed. i have had it laying around and have been waiting to use it. i am doing a carb swap though.
            the distance from the cam to the distibutor mount is the same from a 302 to a 351. the difference is that the 351 oil pump uses a 5/16" drive shaft, a 302 oil pump uses a 1/4" shaft.
              I thought someone else would know for sure. Thank you for the clarification.
                Really? I always used a 5/16" socket to prime my motors. And I've never had a 351W
                  351 uses a 3/8" shaft
                    alright then it is 5/16" for a 302 and 3/8" for a 351. its been a long time since ive had to prime one.
