codes
    codes
    i got these codes with koer test any help on this would be helpful
    94 secondary air system inoperative
    44 thermactor air system inoperative
    75 brake switch circuit closed or eca/pcm ckt open
    I'll crack open the book when I get home.
      44 and 94 are smog pump related, if yours is gone that will be why. If its not gone, probably the ports in the back of the heads are clogged. It doesnt affect anything.
      75 probably means someone was stepping on the brake while the test was being run. Also not anything to worry about.
        http://www.troublecodes.net/Ford/
          thanks for the info
            Aren't you supposed to step on the brake as part of the test?
              Yes IIRC
                only for part of the KOER
                  some want it, but its a press and release. 75 means it was held down, or the brake switch is shorted. If the brake lights work normaly, the switch is fine.
