351 build ideas? what heads?
    A longrod motor would be a great choice, that's that the TwEECer is for lol... I got my L motor ready made, but upon a new build a longrod would definitely be one of the considerations...
    https://www.facebook.com/jason.baker.1614
    1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
    1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
    2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
    2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
      if i was going to do a full new bottom end it would be the proven 393 stroker, i think that would give me all of the power in the world especially if it was fed by 6-10psi
        Can you still buy assembled 393 shortblocks from FRPP?
          FFRP has a 427 small block
          1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
              Back when I contemplated a nengine build for the red box, my plan was to use Larry's layout for a 351 long rod. I have the F4 block to start with, and I planned to use AFR 165 heads, a Stealth intake, BG 625, etc; just like he outlined. The driveability and potential power numbers kind of seal the deal. But, when you start to add it all up, it gets expensive really quickly, especially when you do it the right way, which is the only way. So that kind of turned me off; that and the fact that the transmission wouldn't be long for the world behind that engine.
              But, should I ever build a driveable performance engine, that would be my choice.
                P.S.: FRPP shortblocks, long blocks, and crate engines are all overpriced.
                  True. That sort of engine might be one justifiable reason to actually use a C6.
                    P.S.: FRPP everything is way overpriced.
                    Fixed that.
                      Originally posted by 70torino429 View Post
                      whats the deal?
                      What's the deal?
                      This thread is rapidly approaching 'Magazine Build' territory, and to be honest with you, I really don't want to have any part of it. I could really care less whether or not you actually follow any advice I give, because if one makes it a point to offer actual tech advice to other people on a message board, then that person must first develop a thick skin, as most advice often goes.....ignored.
                      But at this point, judging by your completely clueless response, and speed to which you responded, it's clear that you didn't even bother to read anything listed....either time I posted a link to it.
                      That's completely your choice, of course. But at this point, I'm not really sure you have even the slightest clue as to what the hell you are doing, other than yanking everyone's chain here. Had you actually read what was posted, you would have realized, in short order, that the short-block combination I presented would have been perfect for what you were attempting to do, simply because this is almost the easiest engine combination to tune for.
                      Had you actually bothered to peruse what information I had posted....long-rod engines are perfect for smaller cylinder heads (excellent match for the GT40 head you were speaking of using), smaller camshafts (TFS Stage I you mentioned, I believe?), and with the smaller cams....you don't fuck up the vacuum signal, which is almost the most difficult thing to correct for with tuning an EFI setup.
                      Having actually driven the two cars I installed my two long-rod-build engines into....provided you actually follow what was posted, your problem is going to be not having enough tire to get it to hook up afterwards. This is why I state that this thread has gone the way of 'magazine builds', as in an inexperienced half-wit shows up, and begins mentioning building supercharged strokers....just like they do in the 'magazines', and having no idea just how difficult it is, or how expensive it gets, just to get that much power to the ground....when a 'mild', non-stroker and non-supercharged 400HP engine presents enough problems all by itself.
                      This combo, with the heads and cam you suggested, can produce 400 hp....and produces power pretty much anywhere in the RPM range. If that isn't enough for you....on a budget, mind you....I wish you luck with your quest for Magazine Insanity.
                        arguing with you would be like arguing with an 8 year old, they whine, bitch and moan till they get what they want and then 10 minutes later they find something else to bitch about , soooo im not going there. i did in fact read everything posted and ive read over your long rod thread multiple times.
                        your points are taken, albeit it seems you threw alot of them out there just in spite that your pissed off at someone or something, some of your points do make sense.
                          AODs can be made every bit as strong without the bulk of the C6. They exist capable of handling 1000 hp, though at that level the pricing gets pretty insane. Stock aod would not be happy though.
                            I would go 4R70w, identical to the AOD, and even more electronics to play with
                              ill stick with the aod, i think it can be built up good enough for any kind of abuse. i see some aods sold to go behind 460s so the potential is there. 4R70w would be neat though, what kind of controller are you using for it?
                              maybe some day i could see your car in person, and see how much of a difference the 4r70w makes, since ive heard its alot better out of the box than the aod
                                Lentech!!!
