Mark 7 Engine codes
    Mark 7 Engine codes
    KOEO
    67 neutral drive switch or gear switch or pressure switch or AC something
    32 egr valve position sensor or pressure feedback egr sensor. egr not opening or closing
    KOER
    12 cannot raise speed above normal idle. Is there a solenoid for that?
    gonna pull the egr and check it's condition.
    2000 Grand Marquis LS
    Mercury Owners Group member
    Sounds like an egr valve issue and the idle bypass solenoid has an issue
      idle bypass solenoid?
      Where's this?
      Is an egr & sensor from my CFI the same? Swap to test?
        egr valve and sensor probably the same on the CFI car. That specific code sounds more like vacuum plumbing issues though. If its not getting any vacuum, it can't open. Check the green line for cracks and that rubber connector doodad for leaks. I think the EGR solenoid is over on the passenger fender, behind the strut tower, kind of crammed in the corner where you can't see it.
        Code 12 is probably the IAC, film canister looking thing opposite the EGR valve. Clean with carb cleaner and see if it starts working.
        67 probably means the climate controls were switched on when you checked for codes. Not important.
          Thanks, I will try to look into those tonight
          Does the IAC have a gasket that will need replaced if I pull it off?
            you can usually reuse the gasket
              So just pull it off an spray the crap out of it.. literally
              Darn thing is averaging 11 mpg..
              Thanks.
                11 mpg? thats awful. Sounds like vacuum leakage if I had to guess.
                  Yea, definitely got something going on...
                    May just switch it to CFI, that works so much better..
