which size glasspacks?
    Looking to get a basic dual setup happening but am a total n00b and don't know what sizes I should be going with - I see a ton of different options on eBay.
    Need a lot more details on what your exhaust system will be. What diameter pipe? Are you cobbling it together from parts you can purchase off the shelf, or having a shop bend it up for you? By size, do you mean inlet/outlet diameter, or length, or both?
      From the Thrush brand you can get a glasspack that's 2.25" in/out and 31" in length ... highly recommended if you can manage to fit them under the car.
        a shop will be doing it ultimately, but i am curious all the same. wondered about length.
          Still, it'd be helpful to know what pipe diameter and configuration they'll be using. For example, for a direct-replacement installation, Walker has some offset configuration glasspacks in 2" in and out, or for all we know you might be having custom long-tube headers built and would prefer a set of 4" diameter Flowtech Purple Hornies.
            I believe you had said 2.25" at one point... If you are going custom bent you can quite literally fit almost any length under the car but the standard 18" case should be fine for what you have with cats and such. Stay away from Chery Bomb, every pair I have used has either sounded like ass or burnt out in a week. Thrush, Flo-pro and Flowtech(Red Hots or Purple Hornies) are the ones to use.
            Purple Hornies only come in 2.25" btw. Even the headder mount ones with the 3" outlets have the 2.25" core. That said, that standard ones are a VERY nice sounding muffler.
            1990 LTD Crown Vic w/ dead 5.0
            1984 Pontiac 6000 cammed 2.5L Iron Duke
            1986 F-150 300 6cyl 5spd.
            1994 Crown Vic... Free, bad trans?
              It won't let me edit now... I had you confused with andymac...
                Either way, it is very easy to fit 2.25" pipes if you cut the original system in front of the Y pipe flanges. I used four 45 degree bends to adapt to those when I first did duals on the wagon, and clamped the 2.25" ID swages directly to the pipes behind the cats.
                  I have 2 31 inch thrush glasspacks on my linc they sound awsome!!
                    I would seriously consider flowmaster. They sound great on these panthers. If i could make a suggestion, flowmaster super 44's and turndowns at the rear axle. You will be very pleased if you go that route. Its the real deal muscle sound, they sound a little "fake" on some trucks and other stuff but we lucked out with the panther sound... In a month so far, 2 people have asked me what motor I swapped in... i'm rockin the stock LOPO 302 haha.
                    its what i have and heres a vid of it
                    http://www.youtube.com/user/91Marqui.../0/N10gw4J30XQ
                      Flowbastards cost a lot, and depending on the configuration, not everyone can take the noise. Plus, some localities are less tolerant than others on the subject of whether to run tailpipes.
                      As for being "the real deal musclecar sound", I was amused to discover that Flowmaster didn't enter the marketplace till around 1980!
                        yeh trust me i know, their $140 each here in canada plus 15% tax... and thats when cars stopped sounding good so flowmaster had a purpose after the muscle car era to bring back that sound to people who wanted it. If someone is looking to run glasspacks, noise is probly wanted, I would prefer the noise of a flowmaster over glasspack myself. just my 2 cents.
                          I would recommend a Thrush glasspack if you wan that deep chambered tone. They're 30 bucks, come with a lifetime warranty and flow better than a Flowmaster 40. A lot of guys are using them on their 350 GM trucks and they sound amazing, nothing like you'd expenct from a 30 dollar muffler. I think I may try them when I put tails on my Mustang if I don't go with Magnaflow.
                          Not exactly your setup and not good sound quality but it's the closest I could find to your application: http://www.youtube.com/watch?v=7S_nmfsHpaA
                          I can post better vids with good sound quality but they won't be a lopo Vic, might be a 350 or a 4.6L Vic but it gives you an idea of how they sound.
                            Hey merc91, why didn't u get some V-force mufflers from Flo-Pro? They are WAY cheaper than flowmaster, and they are made in Canada.
                            As for what size packs to run I would say 18 inch or so shell would work the best.
                              I have generic glasspacks, but I got them 45"- 48" long under the HillbillySUV.
                              They sound much better than they have a right to. They sound more like a performance muffler than a glasspack. They are just loud enough without being annoying.
                              Axle codes
                              Open/Lock/Ratio #
                              G / H / 2.26
                              B / C / 2.47
                              8 / M / 2.73
                              7 / - / 3.07
                              Y / Z / 3.08
                              4 / D / 3.42
                              F / R / 3.45
                              5 / E / 3.27
                              6 / W / 3.73
                              2 / K / 3.55
                              A / - / 3.63
                              J / - / 3.85
