Super Unknown ... blown head gasket?
    Drove the car home about 1.5 miles from the storage unit yesterday and noticed smoke/steam coming from the back two tubes of the driver's side header. Got underneath the car today and I found a residue on the head-to-block seam and a trail of corrosion on the header from that spot.
    Is this a blown head gasket? I can't see any cracks in the head or block. No oil in the coolant or coolant in the oil.
    is this car still EFI? in the winter, the wagon blew one of them EGR coolant hoses and the driverside manifold and block got covered in coolant and made a smoke show.
      dont have a panic attack just yet ....
      very first thing I would do is inspect the egr coolant hoses for leaks.
      Rent a cooling system pressure tester from the auto parts store, pressurize the sytem and check for any obvious leaks.
        looks like condensation
          egr cooler hoses plugged.....iirc pipe plug in the lower intake and a piece of hose and a bolt on the heater pipe nipple
            wasnt sure if the EGR hoses had been by-passed, I suspected they had been.
            while its most likely condensation.... not a bad idea to check the other possibilities
              Head gaskets don't usually blow to the outside like that, but a pressure test should tell you. I'd bet its probably something a lot simpler tho.
