When making a turn...and the car bogs/hesitate...
    I noticed yesterday when i make a turn and stay on gas it bogs and than when i straighten out it hesitates and than goes. I was thinking it was the fuel sock and/ or fuel pump being to high or sock being off (installed after market pump i believe its a 190 or 160),but the pump is mounted low and sock is on so idk... doesn't affect driving car to much but it is annoying. I was also thinking it could be the sock being smaller.
    How full was the tank? How old is the fuel filter?
      new fuel... start around a half i think
        new fuel, or new fuel filter?
          fuel, maybe i should replace the filter
            often!
              I'd think the pump is too high in the tank. Leave more fuel in it or redo your pump mount
                does it do it when you turn both ways or only left? If i turn left hard with low fuel it cuts out, hesitates, then refires and takes off... pump is on drivers side of the tank so it's the fuel sliding away from the pump pickup.
                1986 Ford Contry Squire: HO engine swap, 3G alternator, 3.73 gears, rear air springs, Class III 8000 lb hitch... potential tow rig for my Blazer trail toy??
                  i ll have to check for that i dont remember
                    only happens bad when making a left hand turn (did it 90 degree and some at lesser angles)
                    This time it was pulling onto a high way from a street hit the gas to turn it went and than when i got 90 it stopped and than went
                      happens with my car to only on left turns, but the fuller the tank the less the hesitation. I figured it was the where the pickup was mounted.
                      -2004 Crown Victoria Police Interceptor - Daily Driver - 17" Bullitt's, 235/55/17 Goodyear Eagles, Ex-NH State Police, best 1/4 mile time; 15.3 @ 90 mph
                      -1987 Crown Victoria 2-Door - Project - 90k miles, Summit chambered muffler, Sunpro gauges, parked since 2010, fate tbd
