Drain plug seal/gasket questions
    My car's oil pan drain plugs, especially the front one, are not sealing properly.
    A little background:
    -Plugs that were in the car when I got it were overtightened/messed up. They turned hard all the way out.
    -Pan threads looked good, so I went and got new plugs. Computer system at said parts store lists a metric-thread plug for a 91' full-size ford.
    I did not realize this (or look at the #'s) and just assumed I had the right part. Looking back, I'm thinking since the 4.6 was used in the 91' TC, that might account for the error in the system.
    -So, obviously, when I tried the new plugs they didn't fit.
    -Stumped (and not realizing my error) I decided to put the old drain plugs back in (stripped as they were, at least they fit) and bring it to the garage around the corner from me.
    -They "chased" the threads out and put new drain plugs in, and also let me know that the right size was 1/2" x 20. The also went on to say that my pan was "messed-up" and that they had to tighten the plugs more than they liked to get a good seal, (and they did get a good seal BTW).
    -Well I changed the oil early thinking there was probably lots of crap still in the engine from years of sitting. Plugs came out okay and went back in okay.
    -I snugged them up real good, being careful not to overtighten.
    -Got oil seeping ever so slowly out the front one. The rear one seeped ever so slightly and has since sealed.
    -I have tightened the plugs as much as I dare to. The threads do feel a tad sloppy/loose, but they are not stripping, I can "feel" the tension on the bolt head as I snug it down onto the gasket.
    Okay.......sorry for the novel.......back to my question.
    These are the "help" brand drain plugs and they use a large wide plastic washer with tiny ribs/lines on it.
    Garage suggested switching to fiber gaskets/washers and replacing every time I change the oil. (that seems ridiculious to me) (but who knows?).
    I picked up a gasket assortment.......AND..... also an assortment of o-rings.
    The o-rings are the real fat ones, and I found a size that seams to fit perfect (I brought the metric plugs back for some 1/2x20's for spares).
    My Question:
    Will O-rings hold up or will they melt??
    Former panther owner
    1981 CV 351 4bbl
    1991 CV 302 EFI
    Some newer cars do use an O-ring type seal on the oil drain plug. Depending on the composition or the rubber (don't suppose they're Viton? ) and the thickness of the O-rings, I imagine they could very well help.
      The O-Rings will work, but, the fiber gaskets will be better.
        yucatechs 89 has metric drain plugs.....skips 90 has std plugs.......really gotta watch the 89 up 302 drain plugs for the right thread
          I did not know that about some 302's having metric plugs. (good to know)
          I don't know what brand these o-rings I got were. I got them at Bonds, which is "parts-master".
          They are black in color (I think I've seen red/orange one's somewhere).
          Is there like a color-coded heat range for o-rings or something?
          As for fiber vs o-ring....the assortment I got has fiber gaskets.....but not as thick/wide as the o-rings are.
          So while the fiber (I guess) is tougher, the o-ring seems to fit better.
          Which would be the better trade-off?
          1981 CV 351 4bbl
          1991 CV 302 EFI
            I'd take one of those O rings and put it in a small cup with a little bit of oil covering it. Let it sit there a couple weeks and see if it distintegrates or if it remains a normal rubber compound. If it holds up, I'd say use that. Not all rubbers are oil safe, read the warnings on a condom about lubricants sometime.
              I havn't used a condom in years.
              Seriously though, thanks, I'll try that.
              1981 CV 351 4bbl
              1991 CV 302 EFI
                sorry for your luck????
                  Haha.....I was waiting for that.
                  Nope, happily married.....and "snipped".
                  ......Don't miss having to wear those.
                  1981 CV 351 4bbl
                  1991 CV 302 EFI
                    Okay.......back on topic.....
                    I've got a couple of those o-rings sitting submerged in a small container of used motor oil.
                    Be interesting to see if they break down or not.
                    My father in law also pointed out that if those o-rings were to split apart it most likely would end very badly.....
                    On a different note.....
                    I put some teflon tape at the base of the threads of the front plug as well as using a fiber gasket today and so far.....no more leak.
                    1981 CV 351 4bbl
                    1991 CV 302 EFI
                      If the teflon tape seals it, spectacular. If it doesn't, you might consider going to a single oversize drain plug. Sounds like the threads in the pan itself are getting tired if a new standard sized plug feels loose in there.
                        One more thing I forgot to mention.
                        I was told that the drain plugs weren't going in "straight" and that was why the old ones were messed up, they were overtighening them to get a good seal.
                        Personally, I thought the guy was mistaken, as it looked alright to me.
                        But....looking at the old gasket....for being such a large (and wide) one....it was kinda' messed up and out of shape. (probably why it wasn't sealing well).
                        Time will tell on this one.
                        1981 CV 351 4bbl
                        1991 CV 302 EFI
                          I checked on my little O-ring experiment today. (oil change coming up soon).
                          They were fine. Probably will try them out when I change the oil.
                          1981 CV 351 4bbl
                          1991 CV 302 EFI
                            A few years back when my mom had her 86 TC, the front drain plug got stripped out. It was replaced with a rubber plug. Dont know if those are still around, this was several years ago. Cant go wrong with teflon tape.
                            NA-15.78@91.21, 80hp shot-14.48@96.21
                              Well, did my oil change today. I tried out the o-rings. I didn't like what I saw and put the gaskets I had been using back in. The o-rings squished out a lot more than I expected. front one was okay, but the back one was odd. It verified for me that the rear drain hole is not perfectly straight. I could see the o-ring being squished out more on one side.
                              I think the drain plugs out there that use a rubber seal use a harder compound and have a recessed area to hold it in place.
                              1981 CV 351 4bbl
                              1991 CV 302 EFI
