Wich stock 351w intake is better? I know none of them are as good as aftermarket, but as far as stock intakes go wich is the one to get?
Stock 351w 4bbl intake
You can get a used aftermarket just as cheap. I only paid 100 bucks for a polished edelbrock 4bbl intake on ebay.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
The earlier, the better. If you go 1969, you will have those four extra holt holes (I wouldn't leave them open - can't if you'll have any water jacket issues or not) unless you are using 1969 351W heads (in which case it'll be a perfect fit).1990 Country Squire - under restoration
Not sure anyone has really put those on a flow bench. Usually the first thing people do when trying to get more out of a motor is put the stock intake in the trash. I'd say get whats available and port it. I'm guessing you have some special need for an OEM intake manifold?86 Lincoln Town Car (Galactica).
What I remember reading on jason.fletcher.net before it went AWOL (permanently "under construction", from what I can tell) is that the original '69 low-rise intakes and 4V EGR intakes from the '80s generally performed about the same - or at least, they would if they follow the same trend as 302 manifolds. The site owner had posted flow numbers for a variety of factory intakes, and the way I remember it, the '83-'85 Rustang intakes actually flowed slightly better than the vintage factory low-rise stuff. Still no good at much over 4500rpm, but a great low-RPM street intake.
+1 on why you must have a factory intake, with Performer 2181s so readily available for cheap.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by GilroyRacing View PostWich stock 351w intake is better?
Didn't the GT350 get a 289? I remember reading that the Edelbrock F4B was basically identical to the C9OX, etc. (Ford and Shelby versions) and that nowadays you'd normally buy a PN 7121 "Performer RPM" fro your 289 or 302 unless you had to have the correct vintage look.
Handy Performer 351 (2181) linky, nice price ($49 as of 6:30am EST): http://cgi.ebay.com/ebaymotors/ford-...Q5fAccessories2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostDidn't the GT350 get a 289? I remember reading that the Edelbrock F4B was basically identical to the C9OX, etc. (Ford and Shelby versions) and that nowadays you'd normally buy a PN 7121 "Performer RPM" fro your 289 or 302 unless you had to have the correct vintage look.
Handy Performer 351 (2181) linky, nice price ($49 as of 6:30am EST): http://cgi.ebay.com/ebaymotors/ford-...Q5fAccessoriesFormer panther owner
1981 CV 351 4bbl
1991 CV 302 EFI
Originally posted by andymac0035 View Post65-67 GT-350's used the 289, then switched to a 302 in 68' and went to the new 351w for the 69 (and 70) model year.
