Originally posted by LTDMike
View Post
Has anyone had this happen?
Originally posted by CheeseSteakJim View PostMarking it isn't necessary anyway... the driveshaft is independently balanced. Its position no effect on any other part of the drivetrain, nor vice versa.
It says to mark it in the book. It seems to indicate the whole line was dynamically balanced, but I know thats not so. I've never had it make any noticeable difference when I've re-installed the driveshaft to tell you the truth.
Trans yoke has no funny splines as far as I'm aware, or at least I've never run into that in the however many driveshafts I've had in and out over the years.86 Lincoln Town Car (Galactica).
Originally posted by 1987cp View PostOdd spline? Sounds more like a damaged output shaft ....
Sorry to bring my old thread back from the dead, but i got it fixed somewhat. The u-joints were loose and a shop by my house was able to put i guess larger caps in to compensate for the wear. I watch them actually have to press in the caps so i'm guessing it will be ok.
But now i have a new problem and some questions... After they did the new u-joints they took it for a spin and it was making almost the exact noise when you let off the gas so they pulled my diff cover off and found some carnage, looks like pinion is missing a tooth, found it laying in the bottom of the pumpkin.
Now my questions are how many splines are our axles? I am guessing 28, would a mustang t-lock fit from fordracing? And finally are 4.10 gears too much for our cars? I dont go on the highway much and they would be free lol
[QUOTE=wazzup242;494672
Now my questions are how many splines are our axles? I am guessing 28, would a mustang t-lock fit from fordracing? And finally are 4.10 gears too much for our cars? I dont go on the highway much and they would be free lol[/QUOTE]
1. Yep, 28 splines, unless you own a limo.
2. Yes, it fits.
3. 3.73's for stock engines....but if they're free....go for it.
speedo gears you can get from here:
http://www.latemodelrestoration.com/...matic&x=27&y=4
Can probably also get one from a Ford dealer. They're not expensive.
With a 4.10, you may not be able to get the speedometer accurate though. It depends on the number of driven teeth in the transmission. The special order high tooth count gears don't hold up well from what I understand.
Traction lock, shop around. Truth be told, in your shoes I'd go new, unless its real cheap. The rebuild kit prices have gone up, so if you spend a bunch on a used one and pay someone to rebuild it, you won't save anything. You can do it yourself, but its still going to come down to how much money you have into it vs buying new. Summit lists brand new traction locks for 200 bucks, and you might find that cheaper somewhere else.86 Lincoln Town Car (Galactica).
Explorers are 31 spline. Gears would work if they weren't trashed.86 Lincoln Town Car (Galactica).
