67 ltd WONT START!!!
    DAMN!!! i just replaced the points (properly gapped), condenser on the distributor. the car ran like a champ! now it sits.. the car is parked on a hill, it had little or no gas in it. i added 3 gallons of gas. i tried to start the car. it would go rurururururu and wouldnt turn over and start. i gave the gas pedal a slight push and tried to start it. it almost started but didnt. i thought the battery was the culprit b/c it was so old, i changed the battery. i turned the key and it started and then stopped. now i when i turn the key i hear "tick tick tick tick tick" maybe i wrecked the starter trying to turn it on so many times?! maybe i flooded it?! im all out of ideas.
    if its the start where would that might located?!
    any help would be greatfull
    thanks fellas
    ______________________________________
    67 Ltd tudor
    67 Ltd 4door
    85 Ltd 4door
    The "ticky" sound from the starter is the solenoid engaging the gear, but it seems like you're out of battery juice (again) to spin the thing - charge up the battery good, and attempt starting. Once car is running measure voltage at the battery, should be at least 13 volts, preferably around 14.
    By the way, aren't you supposed to pump the throttle a few times before even turning the key? I always did this with my old Chev (Holley carb), floor the pedal and set the choke (manual choke) then push pedal to floor two more times and hit the start, she fired up every single time even after sitting under a foot of snow for about a month!
      also if it sat for a while, the carb fuel bowl can be completly empty and just turning the engine over isent always enough. try finding the vent on the carb and by using a gas bottle, fill the carb up with fuel and that should be enough time to get the fuel flowing a gain. i do this to my boat every spring when i summerize it.
        Yeah, I'm guessing since you didn't pump the pedal a couple of times, it had nothing to burn in order to get started. As Ivan mentioned, pumping the pedal sets the choke, and also uses a part of the carburetor called the accelerator pump to squirt a little bit of fuel into the engine to help it start. Pump it a few times and it'll probably start right up, provided you charge your battery back up again. And if that doesn't work, just dump a little bit of gas right down the carburetor bowls and it should take right off.
          its a carb mang, gotta pump the pedal a couple times. Most carb cars are two pump chumps, but thats not a bad thing in this case.
            thanks mangs.
            carbs.. still learning lol
            67 Ltd tudor
            67 Ltd 4door
            85 Ltd 4door
              charge the battery.......pump the pedal a few times then try to start it.......if it dont start check for spark.......if no spark, you got junk chinese points
                HAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA!!!!!
                THE POINTS!! I REAJUSTED THE POINTS!! SHE LIVES!!!! HAAAAAAAAAAAAAAAAA!!!!
                i got the car to run with start up fluid, it ran then i made a u turn to go down the hill i park my cars at. the car died and i lost all power. long story short i ended up facing oncoming traffic. a cop came by and helped me out. the cop told me he owns a 66 galaxie with a 289 motor. he told me to adjust the points and BAM! it started right up!! i adjusted the idle and it runs great!
                gas was the problem facing up hill then spark when facing down hill.
                67 Ltd tudor
                67 Ltd 4door
                85 Ltd 4door
                  lol, well good thing you now know what her limitations are, haha!
                    Ah breaker points. Have you purchased and learned to operate a dwell-tach yet? Does the distributor on that allow on the fly dwell adjustments, or is it just a matter of tweaking the gap to get the right dwell?
                    PS, if you have NFC what I'm talking about, its time to learn the old school ignition systems
                    For what its worth, I had breaker points in my Beetle for about a month, then replaced that garbage with a Pertronix ignitor kit. Its a drop-in solid state electronic ignition thing that goes right in the stock distributor and plugs into the stock coil. Works great, and no points to meddle with. I had the points, a screwdriver and a matchbook in the glovebox for 4 years just in case and never once touched them.
                      to tell you the truth i dont really know about the dwells. im really new at this. the only thing that i know is that the car has powersteering, brake booster and an elctronic choke, which was very odd. nice though. i only know these b/c the other galaxies that i test drove didnt have them.
                      yes, im going to buy a pertronix ignitor kit. the cop that helped me told me its definately worth the money.
                      67 Ltd tudor
                      67 Ltd 4door
                      85 Ltd 4door
                        dwell is basically a fancier way of fine tuning the point gap. Its the amount of time in crankshaft degrees that the points are closed. Theres a spec in the book for it, and you check it with a dwell meter. Or, you just use a matchbook and gap the points and go down the road.
                          PS, if you have NFC what I'm talking about, it's time to go Duraspark and never look back
                          Fixed that.
                            Or that. Points suck and they went away for good reason.
                              but they can survive an EMP, whereas Duraspart and EFI can't :p
