I have a 1989 Grand Marquis that is completely stock -- it has a 302 w/ sequential injection, AOD transmission, 3:55 rear diff ratio. It currently has about 138,000 miles. It's in pretty good condition. I've owned it for about a year and a half.
Lately, I've noticed what seems to be an engine misfire although it might be something in the transmission.
The symptoms seem to occur only at low engine speeds, high load and when I open the throttle and specifically consist of intermittent "cough-like" power loss pulses (for lack of better terminology).
For example, this might happen at about 40 to 45 mph in overdrive when I want to accelerate hard on the freeway. Or it might happen in Direct at about 25 to 35 mph when I try to accelerate going up a real steep hill.
There are no sounds at all associated with the symptoms. Sometimes it almost feels like I'm going over a bump. In fact, when it first started happening, I thought I had gone over a bump, but there was no bump in the roadway.
Otherwise, the engine and transmission seem to perform flawlessly with plenty of power and smooth running at high rpms. Idle is perfect too. I pulled the cap and rotor and checked it. There was a bit of corrosion, which I cleaned up, but there was no apparent effect on the symptoms.
I'm not an experienced mechanic, but my intuition tells me that if it were something like bad plug wires, then the engine would miss at high rpms, but that doesn't happen.
Any thoughts? Thanks.
