Just a reality check for those who's goal continues to be converting their CV/GM over to a HO configuration. A box stock Mustang with an AOD ran in the low to mid 15's with factory tires.
Put the same engine and transmission into a CV/GM and you have a high 15 low 16 second car at best. If this is your end goal, then go for it. Don't sit and wonder why your HO conversion using stock factory HO parts doesn't get you into the 14's or doesn't give you the same sensation when you mash the gas as launching the space shuttle. Gears and exhaust will get you into the low 15's and you might even be able to squeek out a very high 14 second pass if you have a set of sticky tires. That is a big maybe depending on your tune.
Compared to a stock set of E7's, GT-40P heads are good for an additional 30HP. This has been demonstrated over and over by dyno runs. An Explorer intake is near the same performance with a stock HO cam as a Cobra or even a GT-40 tube intake. This means an additional 10+HP.
Right now, there are a pile of Explorer engines on car-part.com in the $400 range. You can get a 96 Explorer motor with non-P heads for a hundred or so more, but your compression will be lower, and mileage will be somewhat lower also. FRPP only sells standard stainless Mustang headers that fit P heads now, so they are reasonably priced and plentiful. They no longer bother to sell a standard ss set that doesn't fit.
Add up the costs to do your conversion and you will find that an Explorer motor is one hell of a deal..........with an Explorer motor you get a solid shortblock, great heads, a cam pretty close to an HO cam, a great intake, a 65MM throttle body, 19LB injectors, and a cool upper intake cover plate.
On another note, for those who do not realize it, there are tangible benefits in removing your factory fan and installing an electric fan. A stock fan has been proven to suck 20HP from a Mustang at track RPM's.
