On the under drive pulleys, if this is for a 5.0, what is a safe percent of under drive that still will get power to all the stuff that needs power, like the ac, and alternator?
underdrive pulleys and ptv clearance gt40p's and lopo pistons
- Oct 2009
- 2878
- Keene NH
- Send PM
1985 GMC 1500
Tags: None
theres really only one company that even makes an underdrive for the 5.0 panther, so whatever size that is, thats the one to getYou will want to upgrade the alternator though, the stock one just won't keep up with an underdrive pulley.
- Oct 2009
- 2878
- Keene NH
- Send PM
3g I assume? Ive got a question about some heads also, I posted in the 5.0 tech section, maybe you could answer about clearance of gt40p heads on a lopo engine with the flat piston heads and valves? I just don't want to thread jack here."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
- Oct 2009
- 2878
- Keene NH
- Send PM
Apparently they are dished and not relieved, so it should work according to lincolnmania, he said he would be concerned if it were the 86 or 87 because those pistons were flat top. Sorry for misinformation."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Originally posted by 91grandmarquis View PostApparently they are dished and not relieved, so it should work according to lincolnmania, he said he would be concerned if it were the 86 or 87 because those pistons were flat top. Sorry for misinformation.
Still, if you're gonna swap heads on anything always make sure to test your piston-to-valve clearance, whether anyone says it will work or not.1998 Mercury Grand Marquis 131k~ true duals, 2nd cat removed, H-pipe, Xcelerator Turbo mufflers, PI Manifold, 180* Tstat, K&N drop-in.
1985 VW Vanagon 70k~
- Oct 2009
- 2878
- Keene NH
- Send PM
Yeah I know, what is the best way to go about doing that?"Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
easy way is to stick a blob of modeling clay on top of the piston, bolt the head down with a head gasket (used but intact is OK, as long as its the exact same type gasket you plan to use for assembly) and rotate the engine through 2 revolutions to get all the valve events. Measure how thick the clay is where the valves pushed it down, and thats your ptv clearance.86 Lincoln Town Car (Galactica).
- Oct 2009
- 2878
- Keene NH
- Send PM
I am assuming that I will only have to do this on 1 piston, as the rest should be the same?"Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
right. if its OK on one cylinder, it should be OK on the other 7 unless something was done very wrong when the motor or heads were assembled.86 Lincoln Town Car (Galactica).
- Oct 2009
- 2878
- Keene NH
- Send PM
Ok thats what I thought, but you know what assuming does..."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
Here is the under drive pulley for the crankshaft. Midway down the page. You gotta call to order. Website has been funky for a while.
just curious:
How much PTV clearance do you need in a street engine to account for high-rpm stretching/slop/whatever?
Originally posted by 87gtVIC View PostHere is the under drive pulley for the crankshaft. Midway down the page. You gotta call to order. Website has been funky for a while.
http://www.aspracing.com/ford.htm2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
- Oct 2009
- 2878
- Keene NH
- Send PM
Yeah, they are pricey, that will be a later modification."Shakedown"- 1991 Grand Marquis GS Dual exhaust, Magnaflow xl turbos, Rear anti sway bar, Outlaw 1 wheels, 43k miles
1985 GMC 1500
supply and demand.......and they are the only place on the planet that makes the underdrive pulley.........yea i know i cant afford one either
