Finding exhaust leaks
    I've got a medium exhaust leak (doesn't sound like an open pipe, but a bit more than a tick like it used to be) and I'm sort of stumped.
    Stock duals, ancient downpipe/cats but newer H-pipe and tails.
    It appears to be at the cats at the farthest back.
    The previous owner thought it was where the air tubes enter the cats, but I've poked around there fairly thoroughly. It was crusty, but I can't find any holes.
    Ditto for the connections between the H pipe and the cat pipes
    I'm pretty sure it's not the manifold-head seal leaking, because it's not that loud in the engine bay. I haven't really rules out it being the connection from the manifold to the downpipe. I think it could also be leaking from the seal where the H-pipe meets the cat pipe, but with all the rust and the gaskets being oversized, it's hard to see. Could it be leaking from the seams of the cats?
    Are there any tricks to finding a leak? Something to put on and see if it melts? A telltale sign? I can't see any obvious carbon tracking, but it's hard to tell with all the damned rust.
    I've had it up on a lift running, but with the fan and noisy lifters and a generally noisy shop, I couldn't feel or hear anything.
    I really don't have money right now to throw at new downpipes, though I may be able to buy new universal cats if they turn out to be the culprit.
    Stuff something in the tail pipe. That will force exhaust out through any leak making it more obvious.
    2000 Grand Marquis LS
    Mercury Owners Group member
      Thanks, I'll try that.
      I've heard of using tranny fluid down the throat of the engine in combination with that (then shutting the car off while it's still puffing smoke). Is this risky redneckery or a good idea (or both)?
        that would kinda work, but it stinks. Engine oil does the same thing. Could foul the plugs, but thats about the worst thats likely to happen.
          I had a friend who fouled his o2 sensor doing that, thats the worst that could happen. If its cold out you could start her cold and look underneath and you should see were there is "seepage" of exhaust fumes.
          1985 GMC 1500
