could I put a GT40 upper and lower intake on the towncar, along with the GT40 heads to make a real high power beast? i guess my main questions are 1) can the GT40 upper intake be reversed just like the regular HO intake? and 2) do i HAVE TO use a GT40 intake with the GT40 heads? oh yeah and how much power will this make; close to 250/305 or closer to 275/325 :slug:
super HO towncar questions
a GT-40 upper intake and heads on a roller motor will produce close to 350 at the crankhttp://secondhandracing.com/Home.aspx
yes! i have a gt40 intake i plan on installing on my 86 towncar........i need to get the spacer yet (i have tall valve covers) i will let you know how the install goes...........just hate to rip it apart again lol........already runs so well with the ported stock lower........221.8 rwhp, 18-22 mpg, runs good.
scott
