I don't know. It's not one solid piece of metal though. I believe there are some quick connects located along the line. One other that comes to mind is the one that's down and the back of the bottom of the engine.
Hmm.....now that I think of it, I might take a look at that line for laughs and giggles. I gotta take the CV off of the planks to get a jack under the front of the car. Damn lowering springs:smirk:.
if you dead head the line, more than likely, if the pump were good, you'd see over 100psi and your regulator would start leaking were its piched together.
check the vacuum line to the regulator and make sure there is no fuel in the line after the engine just ran(start it up and shut it off), if your all good there, put a pump in it.
THIS.
YOU SHOULD GET 38-42PSI WITH THE RETURN LINE CONNECTED. DON'T BOTHER GETTING THE STUFF TO BLOCK OFF THE RETURN LINE.
Sorry about the caps, I just don't want you spending the extra money. Just trying to get your attention.
Yah, I found a regulator for $25, so I got one. I'll be changing it out this weekend. At this point, I believe the pump is still good because the brief test at the outlet of the fuel filter showed that it was pumping alright.
You can test the regulator by hooking up a hand vacuum pump to it and hooking a fuel pressure gauge up. The pressure should drop when you apply vacuum. If you don't have a hand vacuum pump, you should buy one. They're not too expensive and they're way too handy not to have around if you work on cars a lot.
I changed the fuel pressure regulator with no affect on the s**t performance. I haven't taken it out on the road yet, but by listening to it while playing with the throttle, it wasn't responsive; it'll suck air long before the the throttle would kick in. My parents are calling the mechanic tomorrow to have him look at it. Probably closer to what jayh has been saying all along. I could probably do an in-tank fuel pump install; I came close to doing it last year for my S-10, but NAPA dropped the ball on that one. If I were to try and tackle that project, I would order one from RockAuto and do it in the driveway. So that's that with the CV. On a positive note, I did replace a couple vacuum lines and the whole intake system minus the lower intake, received a thorough cleaning.
