I was comparing the PN's from my 89 Squire to a 92 Vic on advance auto's website. The bushing kits are the same....wonder why the applications from ES doesn't include the boxes???? I also noticed that some of the replacement bushings were poly...and CHEAP
Bushings
the same reason that nobody list Crown Vics shocks under the Camaro part number, they never bothered to chjeck because they dont feel that there is enough of a demand for it to be worth their while.http://secondhandracing.com/Home.aspx
Yeah, well maybe we should mention it to some of these companies...I see plenty of modded boxes running around.
I'm gonna double check the rear bushing PN's at the ford dealer ASAP. Although I'd only use maybe one pair of bushings out of the rear set. I'm really only interested in the front suspension.Builder/Owner of Badass Panther Wagons
Are we talking about rear control arm bushings here or what?86 Lincoln Town Car (Galactica).
Fronts mainly. The rears are prolly the same, but Advance doesn't list the rear bushings for 91-earlier. Only 92-up. Gonna try the dealer to see if the rears are the same. They probably are.Builder/Owner of Badass Panther Wagons
i believe the rear arms are the same up to 97http://secondhandracing.com/Home.aspx
