pos mk7 running like a pos
    As I've been babbling in the WAYWO thread, my mark VII certainly isn't running top notch. I know an internet diagnosis is damn near imposable, but I also know some of you guys know your 5.0's damn well.
    So what's wrong with it? First and foremost, it idles like crap. The engine visibly shakes as if it's misfiring on 1 or 2 cylinders. It also shakes the whole car like some sort of giant viberater. Under 2k, the car has no power what so ever. If you give it any gas, while it's under a load, it shakes, chugs, and backfires out the exhaust until it reluctantly downshifts. Very annoying. It feels like a total turd until about 2500. Once it hits 3k, it pulls like a freight train and couldn't run better. But it feels terribly slow, like my Tempo could beat it slow. From a dead stop it can't even bark one of the el-cheapo tires on the back, and trying a brake stand just makes the engine miss and studder.
    Video of it's slowness in action.
    Now personally I think the problems are related to the fact the car has gray top injectors in it. The injector harness has been numbered, so someone was messing around in there. I have 8, 19lbs EV6 style injectors that I'm going to throw in as soon as the rebuild kit arrives, but with my track record I'm sure they won't make a difference. Only mods are the mufflers are rotted out, and the guy says he hollowed out the cats.
    One would believe that the gray top injectors could mean someone stuck a lopo in there, but it will barley even run at all with the lopo firing order. Also, the way it pulls at 3k, there's no way a lopo would pull all the way to 5k like it does. Computer code is DX3
    So far I have:
    Replaced plugs/wires/cap+rotor/coil
    New fuel filter
    Swapped out my know good IAC
    Checked for vacuum leaks, none readily apparent
    It pulls a steady 17 inHg at idle
    Unhooking the egr does nothing, putting vacuum to the egr kills the engine.
    Timing is at 12* bdtc with spout unplugged. Plugging it in makes it move to wherever.
    No check engine light
    Another thing, the car seems to run better with a vacuum leak. It certainly smooths out the engine.
    The car also will not start with the airbox tube removed unless you give it some gas.
    The car doesn't stall, but it comes close (and actually once has)
    It smells like it's running really rich
    Horrible gas mileage @ 14 mpg
    So could the possibly wrong injectors cause all of this? I'd assume they'd cause more problems at higher rpms, and less at idle but I could be wrong. I'd just like to have all the bases covered since I know with my luck it's going to be a huge problem.
    does it have a miss?
    how come you didnt change the fuel filter?
      Oops, forgot, changed that too.
      The whole engine seems to have a miss. Its just one giant miss fest.
        test fuel psi
        isolate the miss
        test compression on that cylinder
        check injector pulse
        you might want to try swapping map sensors
          i have a set of 19 lbrs with new rings and such,if you feel like making a trip down my way id be happy to help you out.
            sounds like it's running as intended then
              Whats the firing order? Is it a HO?
                grey top injectors eek!
                look like someone might have put a fox lopo in this thing at some time?
                  he said if he swaps firing order it gets worse
                  it sounds like, yes the injectors are wrong, but someone was already chasing this problem?
                    Have you checked it for codes? Bad idle can be caused by faulty O2 sensors or bad temperature sensors. If the O2 sensors are shot or unhooked, the fuel mix is all screwed up and they tend to run very rich, causing the shit fuel economy and rich idle. Check the back of the intake, there ought to be an orange wire grounded to one of the bolts back there. If not, find the wire and hook it up. Thats the ground for the oxygen sensors. It might just be time for new sensors.
                    A stock Mark VII is not exactly a rocketship. They run somewhere around 16 seconds in the 1/4 and about 8 seconds 0-60. Compared to a lopo box, they haul ass but if you've been driving something with a little less pork and a little more ass, you'll notice it.
                      I agree.... check for trouble codes FIRST.
                      make sure the vaccum hose to the Map sensor is intact, not collapsing and has its own dedicated vaccum source.
                      check the fuel pressure regulator. they fail internally some times.
                      also check the vaccum hose for the regulator, should have its own dedicated vaccum source and not kinked.
                        New injectors are in. Old ones do look like they were orange/tan at one point in their lives. Didn't make a bit of difference. Ran a new vacuum line to the map, it's definitely doing something. Unplugging it makes it run even worse-er. All the vacuum lines look good with no leaks. It's been backfiring out of the exhaust even more now. It's really bad. 0-60 is about 13 seconds. I'll check it for codes tomorrow if I get a chance.
                          Got a known good MAP? Swap it in, just for shits and giggles. If it runs better with a vacuum leak, that means it's dumping too much fuel in there, and the extra air is making the mixture more normal.
                            Panther MAP's are the same right? I could throw the one from my box in I guess. I know it's good. It's definitely running rich as hell. You can smell the raw fuel. Also, I think it's down to about 10mpg
                              yes your panther map should be the same
