Hesitation on full acceleration on sefi?
    I full throttle and it take like two seconds till the car notices it? I have a fresh tune up new map sensor, new fuel pump, injectors cleaned out, lots of new vacuum lines. So what can this be?
    how old is the fuel filter? Ever checked it for codes? A TPS with a dead spot can cause this too, may or may not show up on a code scan.
      tps is new and tuned fuel filter two years old maybe. I know still have to redo the film sensor could that be it.
        Change the fuel filter first, its about an annual thing.
        whats a film sensor?
          the key shaped thing at bottom of distributor lol
            Annually? Must have dirty gas where you are at. Mine hasnt been changed in at least 10 yrs. I have one but havent felt the need to change it.
            NA-15.78@91.21, 80hp shot-14.48@96.21
              the only parts in the distributor are the pickup, or bolted to it there is a TFI module. There is no film sensor.
              If you look at the factory service intervals, I'm pretty sure it has fuel filter replacement at 12,000 miles or 12 months.
                iirc the FF is 2/24 interval
                can you measure fuel psi?
                what is your timing set at?
                  how would i go about measuring fuel psi put a gauge on it right lol. I havent checked timing yet either. Idk I gave it to ford they said tfi module was bad and just pulled the spout to solve the problem of it stalling. I putting new tfi module on this week. Maybe that will fix it.
                    theres a test port for a fuel pressure gauge on the front passenger side corner of the fuel rail. It looks like a valve stem you'd find on a tire. There may be a black plastic cap on it.
                      TFI=Thick Film Integrated ignition module=film sensor
                        Yes, I know what TFI stands for. I didn't know if he meant the pickup which is a sensor, or the TFI module, which is not a sensor. Neither item is quite what I'd call key shaped, so its still not clear.
