Would it be easier to remove the lopo engine with the trans attached, and install the HO with trans attached, or just pull the engine and install the HO? Also are replacement motor mounts readily available for my car (mounts are original)?
Engine Swap question
NA-15.78@91.21, 80hp shot-14.48@96.21Tags: None
never had much luck pulling an engine with trans. Sounds like it ought to be easier, but I have never seen it actually work like expected. Maybe with an overhead chain hoist.
mounts are obtainable, but its a bitch to change them with the lower control arms in place. Pull the LCA and its cake.86 Lincoln Town Car (Galactica).
on-topic, so I hope this isn't thread jacking, but how many motor mounts are there on one of our engines? where?sigpic
I did mine this spring with the trans attached, it was a piece of cake.. Hardest part was getting the shifter linkage out of the bushing.Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
Never removed motor and trans at the same time, but just motor is pretty damn easy.
I would never even consider trying to change the motor mounts again without pulling the lower control arms. Its possible, but not worth it by any stretch of the imagination.
Thanks for the advice. I will be using an A-frame and a chain hoist for the removal and install.
Originally posted by 1990LTD View Poston-topic, so I hope this isn't thread jacking, but how many motor mounts are there on one of our engines? where?86 Lincoln Town Car (Galactica).
