How to replace an ignition module?
    Hey guys.
    My ignition module went bad, so I've got a new one. I popped the hood thinking it would be a 5 minute job. How wrong was I! The ignition module bolts are almost impossible to get to because of the thermostat housing and temp sensor.
    My question is, can the module be replaced without removing the whole distributor? Am I going to have to remove the temp sensor etc..?
    Any tips or advice would be appreciated. Thanks
    Danny
    88 GM 5.0 EFI
    2002 Mercury Grand Marquis GS 4.6L V8, 1988 Mercury Grand Marquis GS 5.0L V8, 1979 Lincoln Mark V 6.6L V8, 1977 Lincoln Continental 7.5L V8, 1999 Chevrolet Suburban LT 5.7L V8
    no. The distributor needs to come out (if only an inch) to clear the pins on the module. Use something to mark the position of the rotor in the housing and the housing to the engine before removing it so that you can put it back in EXACTLY where it was. (white out pens are nice for this)
    should be pretty easy that way.
    Pop the cap off of the distributor, mark the position. Mark the position on the housing and engine. Loosen the hold down bolt enough to remove it. replace the module... and reverse. Should take about 15-20 minutes.
    be sure to put some thermal grease between the module and the mounting plate or you'll end up frying the new one.
      That's the kind of info i was looking for, thanks mang!
      Danny
        if you have a timing light, I would reset the timing
          you can, no sweat. if you mark the dissy and base at the same time with a chistle, you will be able to turn the dissy for acess to the 2 bolts that hold the TFI in place. then when done, you just align your marks in the dissy and you will be set.
            The tool I have just won't fit in there unless the distributor is out. Some of them will let you just rotate the dizzy though. Its so easy to yank and re-drop the distributor that its not really worth fighting it. Just make sure you mark the rotor position and ensure it lands there when you put it back together.
              Thanks for the advice guys. I haven't done the job yet and to be honest I was a little nervous about pulling the distributor. For some reason I've got it into my head that something will happen to the shaft down to the oil pump or i won't get something aligned right causing greater issues. I was actually thinking about just loosening the bolt and rotating the distributor enough that i can undo the bolts to the module and then just re-align it back in position and check the timing mark with a gun to make sure.
              Again thanks for the advice guys, really appreciate it!
              Danny
                the shaft shouldn't come out, it has a clip holding it in so it cant come out with the distributor.
                  You shouldn't have to do anything but just rotate the distributor, especially if you get the little round removal tool that's got a thumbwheel.
                  Be warned. Most of the replacement modules come with dilectric grease instead of heat-sink grease. You need heat dope (like you'd put between a CPU and heatsink), not dilectric grease. Use a very fine layer.
                    yes, i second the heat sink goop. i got some from the net and put it on the TFI on my bros lincoln. havent had an issue yet. its good stuff.
                      Don't then, unless you have to. You will still need to mark everything (justin case might show up) as has been mentioned already. Loosen the hold down bolt and turn the distributor in whatever direction will let you get your tool in place, swap, then set the distributor back to the mark you made and done deal.
                      Alex.
