How do i test the mechanical fuel pump on my VV 351? A quick answer would be greatly appreciated!!
Fuel Pump Test
Fuel Pump Test
-Phil
+2003 Acura CL Type S 6-speedTags: None
I would just pull the fuel line from the carb and crank the engine, if you see a good stream of fuel it's good, if little or no fuel then obviously it's bad.2002 Mercury Grand Marquis GS 4.6L V8, 1988 Mercury Grand Marquis GS 5.0L V8, 1979 Lincoln Mark V 6.6L V8, 1977 Lincoln Continental 7.5L V8, 1999 Chevrolet Suburban LT 5.7L V8
okay thanks...it was pumping a large volume of gas out so it seems to be ok.-Phil
