its a brand new egr thou? I was reading a thread and thought maybe my idle screwed screwy and its throwing tv cable and all stuff ascu cause it wierd car shift real fast in od it like 1 st till 25-35 than second than drive right after to move it has to down shift... maybe its the 2.73s thou.
So I changed my tfi module today...
did you replace the egr valve, or the egr regulator? The regulator lives on the fender, and most of the time nobody replaces that. When it acts up, the egr valve opens when it shouldnt, and it does generally stupid things that a code scan won't reveal. If you want to see what its doing, tie in a vacuum gauge to the egr line and go for a drive. If you see that gauge jumping when the car starts hesitating and bogging, you know its related.86 Lincoln Town Car (Galactica).
so i think my distributor might be on wrong tooth cause it wont idle at all now, how do i get it to the right spot to set it to get my right timingsigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
best thing to do would be to bring #1 cyl up on compression stroke. pull your dissy and set it to #1 cyl and use a timing light to set the timming. sometimes its best to do this to start fresh. unless you want to pull up on the dissy and try going one tooth advanced or one tooth retarded. best thing to do when replacing your TFI is to mark the dissy, then rotate it without pulling up on the dissy. that then gives access to the TFI.
get a friend to help you turn the engine over. either by hand or the starter(it helps having the spark plus out). mark your timing markson the balancer and bump the engine over while your finger is over the spark plug hole. you should feel the compression on your thumb, when the piston is on its way up the compression stroke. once you have done this, the pointer for the timing marks on the balancer should point to 0. this means that #1 piston is at TDC. once that is all done, set your timming. iv done this many times with out any issues. maybe someone on here has a better way.
Originally posted by 83countrysquire View Posthow will i know when cycl 1 is at top of compression stroke
