My Transmission
    My Transmission
    My trans seems to be on the way out and I'm kind of worried. It only has 71,000 miles on it too, but it takes a while to shift from second to third and when I shift to drive it makes a loud thump. Anyone know how much it is to rebuild?
    Might just be the pressure is too high. What condition is the TV bushing in? Its on the rod on the side of the CFI unit. If those crumble on a CFI car, the pressure goes high, causing late and rough shifts.
      Luckily they're pretty cheap and easy to replace... far cheaper and easier than a transmission, if you catch it soon enough.
        luckily if it fails on a CFI car, it just won't shift because the pressure goes high. If it fails on an EFI car, you lose the transmission. All things said, I'd rather have it wind the hell out of first gear than blow the tranny up.
          sounds like normal aod behavior to me...
            Thanks, I'll have to check that out
              My AOD is quite verbal when shifting into OD. First through third are fine, but the car bucks a bit sometimes going into overdrive at around 40mph. It seems to be when under less of a load, i.e. light acceleration downhill, coasting, etc. Under moderate/hard acceleration, it shifts smooth as silk.
              1990 LTD Crown Victoria LX. As stock as the day it was born.
              16" HPPs sitting in the garage. That's it for now...kids gotta eat.
                It is always a good idea to manually put it into overdrive by simple shifting it to OD when you are above 55 MPH. Drive in D and shift into OD and your transmission will last longer.
                  my AOD like to shift around 47 into OD and bucks like a mule when doing it. it shifts much smoother at 55-60.
                    AODs do tend to slam overdrive at very light / no throttle. Unfortunately when they shift "right", it usually means the OD band is about to shit itself. Clunk is good.
                      Pretty much exactly how I drive...
                        My od is for interstate only. Bogs at 55mph. 65 mph minimum.
                        1989 Grand Marquis LS
                          mine too..
                          I also have to lift the pedal if I want it to shift into 3rd earlier under light throttle.
                            Mine will clunk at very light / no throttle, or if I lift my foot at 35 mph. Shifts fine at anything over that. It would do that at 40 before I changed rear ends.
                              Consider raising the TV pressure just a little bit, it may help with the shifting into third too early. Also, consider the advice given to others to manually engage OD at a more appropriate speed. It will make the OD parts last longer.
