i can't find my damn manual and it's got all of this stuff listed
brake fluid
rear gear oil (also what oil should i use for this?)
power steering fluid
anyone know what these capacities are in a 90-91? going to flush the power steering system as best i can and replace it with all new type f. don't feel like replacing hoses so i'm just going to put it on stands and use the turkey baster method...suck some out of the reservoir, refill, turn wheels lock to lock, suck out the fluid in the reservoir now, repeat until it's all clean looking like the pretty pink type F.
i also need to bleed my brakes so i don't know how much dot3 to have on hand.
also, noob question: when i've got the car up on stands (so there's no resistance at the wheels i presume?) and i'm turning it lock to lock will the fluid still circulate if the motor isn't running or do i need to run the car as well? i don't know if the turning action of the steering wheel will push fluid through or not.
brake fluid
