Valve Cover Gasket Question...
    UPDATE! Valve cover gaskets
    Yes it is 2:24 and I have been inspecting my car trying to locate and pin the oil that's leaking like Niagara Falls.. and I could see when I jacked my car up was that the oil is coming and covering 3/4 of my oil pan and dripping off of the rear oil drain plug.. However I did notice my power steering has a slight leak and the first spark closest to the rad on the passenger side has this red, corrosive looking liquid(like marvel mystery oil) coming from it. I don't think that is the cause of my oil leak, because it stops there. I will try to get pictures. But I'm so confused. Please tell me it's still the valve cover gaskets and not something more severe
    "Charleston" the 1987 Mercury Grand Marquis LS sedan
      It's probably the pcv screen clogged and blew out the rear lower intake gasket. They leak very very bad when that happens.
      '90 LX 5.0 mustang
      Big plans
        ohhh! sweet jesus! so it was something I was going to replace anyways?! YAY! I was so scared, because I couldn't see where it was coming from! I can go to sleep now. phew!
          Clean off the old drippage, drive the car, and then look to see where it's coming from. Then you'll know.
          P/S pumps are cheap, about $30. Hoses aren't bad either. Type F, the preferred Panther p/s fluid, is quite red.
            Well I did that a few days ago and when I drove it to the library, It had covered the oil pan the same way. It's coming from above the oil pan, where I can't see from under the car. I haven't really taken apart the top of the engine to see any possibilities? But yeah lol
              Not sure what you mean by taking apart the top of the engine ..... unless it's a SEFI car and the airbox is in the way.
              By "above the oil pan", I presume you mean it's dripping down the side of the block above the pan gasket?
