can you test spark plug wires with a multimeter?
I have the 9mm ford racing wires on my 1990 and they've been great but my ignition parts aren't lasting as long as they should. I used blue streak products for the cap/rotor and have only gotten maybe 4 months out of 'em. Last set I used all Motorcraft and got a good bit longer.
questions:
2 - would my car running rich as a result of aging sensors (ACT, ECT, HEGO) have done this to my ignition parts? I also had the PCV system start to clog up on me and send oil into the TB via the breather tube on the valve cover. I know oil and running rich can foul spark plugs, but, will these spark plugs screw up everything else in the chain of ignition command?
2 - can I use m voltmeter to test my wires? There are no cracks in them at all and all of the boots look fine but I want to make sure when I order new tune up parts this week. I also am wary of getting blue streak products again BUT if this can be attributed to something besides part quality.
3 - how long do ignition coils last on these wonderful machines? i've never replaced mine - should i?
thanks guys
questions:
thanks guys
