Can you just cap the vac line from the cruise control at or near the servo?
when deleting thermactor pump
- 2008 Mercury Grand Marquis Ultimate Edition - Daily driver - 4.6 2 valve Mod motor, 4R75E, 2.73s. Bone stockTags: None
Originally posted by 1990LTD View PostCan you just cap the vac line from the cruise control at or near the servo?
when I did mine, I chased that hose back to the tee, and just removed it, the tee, and all the related stuff. I seem to remember a check valve in the hose that gets deleted. I think I used that as a connector in place of the tee so the cruise servo now has a straight vacuum feed from the tree.86 Lincoln Town Car (Galactica).
Originally posted by 86VickyLX View PostYes. That hose goes to a T behind the engine to the vac tree, and to the servo. Just remember now you'll have less vacuum to the cruise, so it may shut off on you on a steep incline...
Cool. Cruise on a steep incline is for suckers anyway.sigpic
also, the hose doesn't actually connect to vacuum, does it? just runs to that thing behind the motor and then to the cruise servo to provide vacuum to it when it's running? i don't have the car here to look at unfortunately. i'm gonna pull all of this stuff out tomorrow when my friend is putting the water pump and brackets, radiator etc back on (something beyond my skills at this point i think, i'd put the brackets on wrong more than likely)Last edited by 1990LTD; 01-26-2011, 01:24 AM.sigpic
hm.....i am half tempted to yank the fan from my aero and install it in place of the pump driven fan and shroud from the 90. wonder how they measure up..i'll check tomorrowsigpic
Originally posted by 1990LTD View Postalso, the hose doesn't actually connect to vacuum, does it? just runs to that thing behind the motor and then to the cruise servo to provide vacuum to it when it's running? i don't have the car here to look at unfortunately. i'm gonna pull all of this stuff out tomorrow when my friend is putting the water pump and brackets, radiator etc back on (something beyond my skills at this point i think, i'd put the brackets on wrong more than likely)
will do. thanks. i think the only play was from the water pump pulley, i've got the pump here and it's pretty fucked.
i recently started hearing some noise at the front of the motor, but the clutch seemed fine.sigpic
Originally posted by 1990LTD View Postwill do. thanks. i think the only play was from the water pump pulley, i've got the pump here and it's pretty fucked.
rough, grinding almost but i can't hear anything. big difference between my hand and the crankshaft spinning it though.
if i lay the pump flat on the floor there's some play in the shaft as wellsigpic
are these things aluminum? i remember my 88 not being aluminum but they probably changed at some point. i don't know if they're gonna take it back for a core charge or not.sigpic
Originally posted by 1990LTD View Postare these things aluminum? i remember my 88 not being aluminum but they probably changed at some point. i don't know if they're gonna take it back for a core charge or not.
and the other one aluminum. The tall tell sign is the heavy duty has 2 extra bolt holes. That makes 3 in total around the water jackets. While the aluminum non HD pump has only 2. Your timing cover has the threads for the 2 missing bolts. So just get 2 bolts if you got the heavy duty one, it's much better than the other.
They will take it as a core. It's original equipment so don't worry about it. I gave autozone a 2g alternator for a core for a 3g alternator.
I take it this is a remanufactured pump?
