I've got a coolant leak. It's collecting on the front of the engine below the thermostat. I'm 99% sure it isn't the thermostat housing.
Weird part is that if I go for a drive coolant will have pooled in that spot below the thermostat. If I watch it idle, or even blip the throttle to a neighbour-friendly extent, I see no coolant exiting anywhere. Sometimes the coolant is also sprayed about the engine bay.
Where should I look? Any ideas on how to make it leak? I'm thinking it's something just busting loose at high rpm.
