ALRIGHT! *finally* got my car on the road.
I set out just to do an HO swap and rebuild along the way.
It's been a long 4 months working nights and some weekends rebuilding and installing, then re-re-re-repairing the installed engine, hahaha.
I also redid the exhaust to make it true dual,
and I also replaced the heater core, which was some time in itself.
So this is the first time I've driven it with quite a bit changed out.
If my sunpro tach is to be trusted, and yes, it's set for 8cyl, I'm idling at no more than 1000 rpm. Usually dips to ~700rpm when at rest at a stoplight.
Light acceleration brings it back to 1000, sometimes 1500 rpm.
Heavier acceleration brings it to 2000 rpm.
Lead foot brings it to a whopping 2200 rpm.
I'm disappointed in my acceleration rate. The lopo was almost more powerful.
However-- the fact that I can't actually get the rpms past 2200 rpm would explain why it has no get up and go!
I'm suspecting that my tv cable isn't adjusted right, and it's just never kicking down.
Could someone confirm this estimate?
I'm not a very experienced/sensitive driver, there are lots of finer points that I'm not able to pick up on yet that someone else would,
but as far as I can tell I can't feel transmission upshifts at all, and the only shift I can feel is the downshift after accelerating if I suddenly take my foot off the gas, a slight shudder-- which might not be a gear shift at all?
Does this mean a super-soft shift pattern? Could too soft a tv-cable lead to no kick-down (for the length of travel of the gas pedal)?
