My '91 Squire is acting very strange. Car cranks up perfectly and runs great.....for a while. The further you drive, the worse it gets. It initially starts missing occasionally and after about 4 miles of driving it will barely run. Bucking, farting, barely moving, but it never shuts off. When it first starts doing it, it idles fine but off idle shakes like half the plug wires are off but then will level out. At the worst of it, you can floor it and it will barely move and shake the car like the engine's coming apart. But in a six mile drive, it never shut off. Let it cool down, starts and runs perfect. Had TFI module tested and came back good. He tested twelve times in a row to get some heat in it but it still tested good. Cap, rotor and coil are new(August) and wires and plugs are about a year old. Any ideas? Pickup possibly? TFI even though it tested good? Anybody heard of this before? Thanks for any help.
Wagon is possessed........
replaced my cats, still had the same problem though it did not want to stay running. Barely drove 2 blocks to the mechanic and had to start at least 20 times. In my case it turned out to be the TPS. Let us know the remedy please, when you get it fixed.90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
So I drove outside of my two mile safe zone last night and sure enough, it did it again. Got home and listened to it closely, Mrltd and 86, I believe you have nailed it. Sounds like the exhaust is having to force it's way through the pipe. Now time for shorty's and H-pipe.1991 CVLX Wagon with 17" Black Bullitts, 1974 AMC Javelin owned since 1985.
Originally posted by 91longroof View PostSo I drove outside of my two mile safe zone last night and sure enough, it did it again. Got home and listened to it closely, Mrltd and 86, I believe you have nailed it. Sounds like the exhaust is having to force it's way through the pipe. Now time for shorty's and H-pipe.
So after much debating and consulting, I went against the grain and tried a new pickup coil. Drove twenty minutes, no issues.I would be more excited but as I pulled in in front of my house, I put the car in reverse, the car died and a puff of smoke came from the drivers side hood area.
Found a 20 gauge fusible link zapped itself for whatever reason. I've looked in my Chilton's but haven't located this link in the diagram. It links what appears to be about 12 gauge pink wire with green tracer to two smaller wires, both pink with green tracers. Anybody had this issue before or know what those go to? I have all lights(outside and dash) and radio, pretty much everything is working, just no start. I can replace the link but any ideas why it fried? Just old age or do I have another issue? Thanks for all the help so far.
I'd say it's time for a wholesale cleaning of all ignition and charging system connections and wiring. Time and time again on here we seem to have weird problems caused by seemingly minor charging system or ignition system maladies.
Originally posted by 91longroof View PostSo after much debating and consulting, I went against the grain and tried a new pickup coil. Drove twenty minutes, no issues.I would be more excited but as I pulled in in front of my house, I put the car in reverse, the car died and a puff of smoke came from the drivers side hood area.
Thanks for that information on the wires. Could the past two weeks of pickup issues have caused the link to weaken? I just don't want to have the same issue again. Luckily, the link is accessible so if it happens again, I can get to it easily.1991 CVLX Wagon with 17" Black Bullitts, 1974 AMC Javelin owned since 1985.
