Identifying Fuel Injectors
    How do I ID the injectors of my EFI 351W? It's from a '96 F-250.
    what color are they... that pretty much tells the tale (unless they're sun faded).
      Thanks Slymer. I think they're orange if memory serves me right. I'll take a look when I get back home today.
        orange=19LB injector. purple=24LB injector and for the life of me, i cant remember what pound grey injectors are(between 10 and 15 anyway lol). maybe cause no one cares
          Thanks Marquisman! I guess they knew back then that this engine was turd-ish. We'll see about that when the time comes.
            they ALWAYS knew lol
              there are two different 19lbs....single hole and four hole i think
                Yeah, go and "muddy up the waters"!! LOL A VERY good point about the holes!!
                  4-holes for increased flow and/or atomization?
                    I have had 2 94+ Windsor motors and they both had Orange 19# injectors
                      I would assume atomization. 19lbs flow is 19lbs flow
                        the grey ones are 14#
                        There's also a whale 13# in there somewhere. No clue what color that one is.
                          Not all those orange/yellow injectors are 19lb. Some are actually 18.25, and the 4hole vs 1hole designs has no effect on what they flow. The 4 holers (Bosch III)have a better spray pattern and I've found them to be slightly more reliable than the Bosch II's.
                          Post #5--> http://www.cadillacforums.com/forums...est-bench.html
                          Type the numbers in the 'Find' (ctrl-F)function in your browser to find your injector --> http://users.erols.com/srweiss/tableifc.htm
                          Still lurking. Cheers!
