Any suggestions on performance rebuild kit for a c6. Dont care how it shifts as ill only be using 1st and reverse. I just think I need stronger clutch packs.
Tranny rebuild time.
1989 Grand Marquis LS
flat black, 650 double pumper, random cam, hei, stealth intake, Police front springs, Wagon rear, Police rear bar, wagon front ,exploder wheels, 205/60-15 fronts 275/60-15 rears, 1 5/8" headers, 2.5" offroad x pipe, Eclipse front bucket seats, Custom floor shifter, 4.10 gears, aluminum driveshaft and daily driven. 16.77@83mphTags: None
get a wide ratio kit for the c6........me thinks they use 4r100 planets.........will still be a 3 speed tho
Wide ratio kit is expensive. Master deluxe overhaul kit from Transtar industries is about 80 bux. The gears in it are low enough just need the clutch packs to handle the torque better. If the planetaries are fucked when I tear it down Ill get the wide ratio pieces. 3 speed is okay because it will never see the highway.1989 Grand Marquis LS
