rebuild an original motor.......i have had no luck with any aftermarket motors or motorcraft, i think we can find a few minutes to show you how at scottfest, but like i said before no tearing cars completely apart!
cardone has been rebuilding stuff FOREVER......with mixed results...but as far as window motors go,i havent noticed any abnormally high warranty issues where i work on those....so price wise.....probably the best of all "evils".......do keep in mind that the "left" and "right" can be reversed on some models(at least thats what they say in the notes)
I think I pitched all my old ones.
I tool one apart & cleaned the commutator & iirc reversed the brushes, but it didn't last long after that....
Where do you get new brushes?
....how many do you need?.....i know someone that may have a few non working ones,ill ask tommorrow ,if he has any i can bring them to SF ...ill update when i know for sure(im going to his place tommorrow morning to get the coupe ready for the trip)
I have been dealing with non opening windows through the last 2 winters, it's been that long since I looked into this....
I know the 2 rears need bushings.
I don't remember if the front pass is just the switch or if the motor is toast.
The drivers front gets power to the connector, it is disconnected (& the door panel has been off for over 2 years), IIRC I had done the bushings & a short time later it just stopped entirely....
So, if I need any, it might be the fronts. What do you think he might want for them?
The tailgate motor has been dead for even longer, but it is not a priority right now.....
......sorry mang...big time bummer here...he has one...but its for a mustang,so it wont work.......i just remember seeing them on the shelf at his shop,but he only has the one left...(he is like me,if it works he saves it for future use or trading meat.....lol)
Thanks Mang, Should I pick up any bushings or anything?
I believe the 'Stang uses the same one...
I have 2 complete, rust free, all electric Mustang doors, but I'm not going to cut them up....
....nope ,i checked at work on my way home,they are real close,but just a lil different where the gear is(id imagine you could make em work,but maybe you would have modify the inside of the door to use them I.E.,drill new mounting points,possibly shim)it may just bolt in,but they sure look kinda different at the gear,and have different part #s and cases
they changed the motor design in 90 or 91......the later model motors are a sealed unit
the older motors the gear housing dates to the mid 60's and the motors early 70's
sure bring some motors we can see if we can bring em back to life, bring bushings or if you dont have little kids 1/4" nuts
well...that explains that....his mustang is a 91.......
