What do you want from this car? Do you want fuel economy or an interesting conversation starter under the hood? Then this is a worthwhile endeavour. If you want a faster car, or one that's more reliable or easy to work on, I don't think it's worthwhile. You'll have more power initially than the CFI 302, but not more than an HO or Explorer or 351 swap, and all three of those setups are FAR cheaper and easier to get more power out of than a 4.6. The cost difference between carbed 351@350hp and a 4.6@350 will be thousands of dollars.
302 to 4.6
Originally posted by storm97 View Postjust looking at options. most likely I will go with a 302 or 351. as i can get the whole car for parts it's a thought.
Originally posted by Mercracer View PostAnother option would be to simply flip the '84 and look for another 95+ Panther as a project car. In 95 the interiors improved exponentially and Ford got more serious about Panther performance.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Just curious what improved significantly in the interiors?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
i traded a two door for a 95 thunderbird with a 4.6 and a fresh 4r70w.......guess i was outta my mind lol
Originally posted by Mercracer View PostDash pad, HVAC controls, seats, door panels, wiring....
It is far easier to find serviceable interior parts also.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Originally posted by pantera77 View PostNo one in their right mind would trade a 2 door for a 95+.
Yes I plan to improve this one. A friend of mine has the TC, it is a drivable car but needs to much work to be a DD, but good for a parts car. this is why I started this tread, to see how much trouble it would be.
very nice!
