I'm A Little Lost
    I'm A Little Lost
    Hi there, I'm a little lost.
    I mean, more so than usual.
    My 1986 Mercury Grand Marquis LS is in the shop due to:
    - leaking intake manifold
    - "BRAKE" lamp coming on when I put pressure on the brake pedal (car still brakes fine)
    - distributor shot (rotor bent, striking the contactors)
    So the intake manifold was removed, but one of the bolts snapped off a long time ago and is stuck in one of the cylinder heads. I'm told that buddy's gonna labour to get the bolt out but he doesn't hold much hope to remove it, meaning that that head has to come off and be sent to a CNC mill or something.
    So I spoke up and said, "instead of me paying 5 hours labour for something that probably won't work, why not just yank BOTH the goddamn heads off and redo the head gaskets?"
    Apparently they don't want to do that because it's hard to do or something.
    The "BRAKE" lamp coming on is apparently due to the proportioning valve's switch dying. He said he might have to jury rig the switch since that part is obsolete. He also made a somewhat derogatory comment about the age of the vehicle in general saying it was "getting too old". I was a little unamused.
    And the distributor, well, it just needs replacement. I have no qualm with that.
    So my question is: Should the mechanic piss around trying to yank the broken stud out of the head or should he have just added $500 to the bill and redone the head gaskets?
    Opinions, please.
    Is the bolt broken off flush in the head? Even if it is, drilling and extracting/tapping it shouldn't be that big of a deal, especially if the lower intake is already off. And why would you replace the headgaskets if there's nothing wrong with them?
    And yes, most shops have no interest in working on 26 year old cars.
      It was sticking out 1/4 of an inch from the head. He broke a drill bit trying to tap it and the bit piece may or may not have fallen into the engine block.
      Well, it occurred to me that if you're going to take off one of the heads, why not take off both and redo the gaskets?
        the head gaskets don't really fail in a way that requires preventative maintenance. If it doesn't seem likely that the broken bolt is coming out and he has to remove one head though, I would definitely do both head gaskets. No point having one new one and one old when you're in that far. Fair bet if he's decent he can get the busted one out tho. If memory serves here, and it may not, those bolts are not blind holes, meaning the back side of the bolt can thread into the lifter galley. Most likely if something can be gotten in there to grab it, you can just spin it straight in and pull the chunk out of the lifter galley.
          Well he said he didn't "have much hope" in getting the bolt out.
          So I wanted the head gaskets done if the one head has to come off.
            I wouldn't bother fucking around with the head gaskets. He obviously doesn't want to work on it and you're gonna pay out the nose if you have him do it.
            I don't see why he wouldn't be able to weld a nut onto the broken bolt but I don't have the car in front of me... If it works for exhaust manifold studs in a cast iron head, I don't know why it wouldn't work for an intake manifold bolt (that has basically become a stud) in a cast iron head. Weld a nut on there, heat up the bolt with a torch and go real slow working it back and forth. If he can get it out there's no reason to touch the gasket.
            I'd pull the bulb for the brake warning light.
            I don't blame him for not wanting to work on 26 year old cars. The cars are dead simple to work on but the jobs generally come with headaches like broken bolts and obsolete parts. He could be doing gravy work on 5-10 year old cars and not pulling his hair out by the end of the day working on yours....just trying to give you his point of view.
              brake warning lights really ought not be ignored. Generally they are there for a reason, and thats to tell you something is wrong so you don't die. On an 86, it works off a shuttle valve that moves if there is a drop in line pressure on one side or the other. An air bubble or a blown line can do this.
                Well this year sometime I wanted to do an engine rebuild anyways (or get a crate motor with fuel injection and stuff), since he says my pissed-on rings are worn (blowby).
                I was gonna hold off on the head gaskets but since one head is likely coming off anyways...
                The BRAKE light issue was diagnosed as a damaged/worn proportioning valve switch, and he seemed confident in that diagnosis, so.....
                  Does the 86 use a fluid switch in the brake fluid reservoir like the later models? Might as well start with the easy stuff since no mention has been made of it.
                  Alex.
                    I have found valves in junk yards. Have also partly dissasembled them and cleaned them out. Found a lot of trash in them due to people not having the fluid flush out every few years. I often flush mine well after a autocross or two. My other vehicles for sure when I cant see the bottom of the master cylinder with the cap removed.
                    You might investagate some other shops next time. These guys seem to do more bitchin than work. Maybe all thier excuses are do to inaptness.
                    Doubt Scott works this way. Too negitive.
                      Yeah if I were you I'd be looking for a guy who specializes in either fords, or old domestics/classics, or both.
                        Just as a point of general interest, what should I expect to pay for the intake manifold regasketing, the distributor replacement and the brake valve switch repair? Roughly.
                          the lower gaskets are inexpensive, but do get the felpro permadry kit for that. the front and rear seal are the only reason. It will never fail. If the shop won't use them, find another shop. The labor cost will be large though since it requires a good 4-6 hours. The distributor can be swapped out in 10 minutes and the switch is 30 minutes tops. Labor is the killer on the lower intake just because you have to pull so much crap off of it.
                            So less than $1000?
                              Dunno about the brake valve but intake and distributor - heck auto MD puts the gasket at $150 at a dealer!
                              Pete
